Use of Column Properties across 100's of rows
Question,
How can I use Column Properties to perform a 1st pass of the Columns using a sigma value, or similar descriptive feature.  Once I have found suspect columns of test data will perform a deeper dive into the data columns.
Attached as snip of the dataset.
Charles
Re: Use of Column Properties across 100's of rows
Look into the "Columns Viewer" platform. It is very well-suited to this use case.
