Unable to open Add-in files in JMP17
Hi there,
I have an old Add-in file (an jmpaddin file) that works well in JMP 16. However, I am unable to open this Add-in file using JMP 17. The error message says " Add-in xxx is invalid for this version of JMP". Is there a way to address this incompatible-version issue?
hogi
Level XIII
Re: Unable to open Add-in files in JMP17
Hm, in general there is just an option to specify a minimum Jmp version.
max version will be available in Jmp 18:
Add-in template to include Maximum JMP Version allowed
So, if this message pops up, somebody seems to be sure that there will be an issue in Jmp 17.
If you need just part of the code, you could rename the file to .zip and extract it.
Then either the code can be found in the jmpcust file - or as individual .jsl files.
Or you could ask the author ...
I assume what needs to be done, is to open the addin for editing, and then resave it, specifying that JMP 17 is a valid release for it to run in.
