Sysy13
Use for loop variable in a formula
Trying with this script but variable "l" is not working, only variable "k" is working. Anyway to solve this?
For( k = 40, k <= 54, k += 2,
	x1 = 1;
	x2 = 8;
	y1 = 40;
	y2 = 54;
	m = (y2 - y1) / (x2 - x1);
	c = y2 - (m * x1);
	l = (k - c) / m;
	dt << New Column( "Test" || Char( k ),
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula(
			If( :Strobe == 1,
				If(
					:Tested Variable == 0 | :Tested Plane == 1,
						If( Left( Right( :"x"n, Column[l] ) ), 1 ) == "1",
					1, Left( Right( :"x"n, (l) ), 1 ) == "0",
					0,
Re: Use for loop variable in a formula
The below script appears to work.  Your supplied script used \\ as comment initiators, where // is what the correct syntax is.
The real working formula really boiled down to using the Substr() function.
The addition of the Eval(Substitute(Expr())) section just changed the value of your l variable into the actual value of l, rather than having the value referenced through the variable.
//k start 40, For each loop will add 2
	x1 = 1;
	x2 = 8;
	y1 = 40;
	y2 = 54;
	c = y2 - (m * x2);
	l = (k - c) / m;
	//l is calculated based on k\
	//Tested variable & Column x & Strobe are the column in my data set
	//If k = 40;, then the readout will be 1st bit from the right of column x;
	//If k = 40;,then the readout will be 8th bit from the right of column x;
	// The variable l needs to be fully parsed in the formula, so that if the
	// value of l changes, it does not change previous formulas
	Eval(
		Substitute(
				Expr(
						Numeric,
						"Continuous",
						Formula(
							theVal = .;
							If( :Strobe == 1,
								If( :Tested Variable == 0 | :Tested Variable == 1,
									theVal = Num( Substr( :x, _l_ , 1 ) )
							theVal;
			Expr( _l_ ), l
A couple of issues
The
Column[ l ]
you specified is incorrect syntax.  Column is a function (), not a matrix [] therefore it needs to be specified as
Column( l )
Next, the formula will have an issue with the value you are assigning.  Given your formula, there are cases where no value will be assigned.  Since a JMP formula returns the last value assigned, you need to explicitly assign a value to the formula for every case.  In my version of your formula, I am using a variable  X to assign your logic to.  I initialize the value to a missing value, and then X is assigned by your If() logic.  I then assure that the calculated value of X is the last value processed, by simply adding
x;
as the last statement in the formula.
	x1 = 1;
	x2 = 8;
	y1 = 40;
	y2 = 54;
	c = y2 - (m * x1);
	l = (k - c) / m;
		Numeric,
		"Continuous",
		Formula(
			x = .;
			If( :Strobe == 1,
				If(
						If( Left( Right( :"x"n, Column(l) ) ),
							1
						) == "1",
					x = 1,
					x = 0,
			x;
Finally, when entering JSL into a Discussion Question, please use the txnelson_0-1702341399738.png icon so the JSL is easier to read by the Community Members
Sysy13
Ok sure sure, will use the icon for next time. Btw the script is not working. Maybe I should further elaborate what are the problems I faced
I have a column with 8bit binary number, for example x="00101101"
Then when my variable k is different, the bit read out from column x should be different
\\k start 40, For each loop will add 2
	x1 = 1;
	x2 = 8;
	y1 = 40;
	y2 = 54;
	c = y2 - (m * x2);
	l = (k - c) / m;
\\l is calculated based on k\
\\Tested variable & Column x & Strobe are the column in my data set
\\If k=40, then the readout will be 1st bit from the right of column x;
\\If k=40, then the readout will be 8th bit from the right of column x;
		Numeric,
		"Continuous",
		Formula(
			If( :Strobe == 1,
				If(
						If(  Right( :"x"n, Column(l) ) ) == "1",
					1, Right( :"x"n, (l) )== "0",
					0,
The issue I faced is jmp cannot recognize what is the bit that I want to read out no matter I put Column(l), l  in the for loop
It would be helpful to if you could attach a sample data table.
With your further explanation, try changing
to
If(  Right( :"x"n, as Column( "Column" || char(l) )== "1"
Sysy13
Hi Jim, here's data table, I put what I expect to see in data table. Column data describe what is the "l" value and which value of "x" it is coming from
	x1 = 1;
	x2 = 8;
	y1 = 40;
	y2 = 54;
	c = y2 - (m * x2);
	l = (k - c) / m;
	Eval(
		Substitute(
				Expr(
						Numeric,
						"Continuous",
						Formula(
							theVal = .;
							If( :Strobe == 1,
							theVal;
			Expr( _l_ ), l
Sysy13
Thx Jim, I think it is working but the print out will be slightly mismatch. It works well when adding ",1" behind  "_l_" in the formula. I attached my full jsl script here
	x1 = 1;
	x2 = 8;
	y1 = 40;
	y2 = 54;
	c = y2 - (m * x2);
	l = (k - c) / m;
	Eval(
		Substitute(
				Expr(
						Numeric,
						"Continuous",
						Formula(
							theVal = .;
							If( :Strobe == 1,
									theVal = Num( Substr( :x, _l_ ,1) )
							theVal;
			Expr( _l_ ), l
You are correct, that is my error.  I will correct my entry.
