statman
Updating JMP PRO to 18.1.1 on Windows
OK, I am not a Windows user, but support some folks that use the Windows version (I run Windows in Parallel on my Mac).  I recently received a notice of an update to 18.1.1.  I downloaded the file and ran it in Windows 11.  I get the option to Modify, Repair or Remove.  I have tried both modify and repair and neither brought the version to 18.1.1.  How do you do it?  So simple on a Mac...
12 REPLIES 12
Re: Updating JMP PRO to 18.1.1 on Windows
@statman , which CPU type are you using on your Mac that is giving you issues with the VM of windows? I had an issue running JMP on a VM (Parallels and VMWare with Windows 11) on an M1 Mac. It would appear to install (icon was there) but it would not launch. Not sure that is what you are seeing given that you were running JMP 18.0.1 already.
Chris Kirchberg, M.S.2
www.jmp.com
hogi
Level XIII
@Mark_Bailey wrote:
I install the latest daily build in R&D every morning for testing. ...
wow!
Just a note with respect to JMP 18.0 and the Python installation.  With 18.1 the layout of the python dlls changed from 18.0 to better support pip installing packages that needed to be build locally.
The JMP installer did NOT properly account for these changes.  So to have a fully functional Python for 18.1 you do indeed need to do the Uninstall, Re-install route rather than the doing an Update or Repair.
