rhakim23
Update table and keep grouped columns
I have a JSL script where I'm updating a JMP table with data from a second table that has columns that are grouped. As it stands the update ungroups all the columns from the second table. I can't find anything in the interactive window to specify keeping it grouped, is this possible? Using JMP 17.2. Thanks!
WebDesignesCrow
Re: Update table and keep grouped columns
Hi @rhakim23 ,
Is it possible to share the mock data table to explain on what you are trying to do?
The JSL script can follow the similar logic afterwards.
Can Tabulate helps to re-group after update?
Or should you update second table from the 1st table?
I think you might have to do this through scripting. Below is one example
dt = open("$SAMPLE_DATA/Big Class.jmp");
dt2 = Open("$SAMPLE_DATA/Big Class Families.jmp");
// create a column groups
dt2 << Group Columns("Stats1", {:age, :sex});
dt2 << Group Columns("Stats2", {:height, :weight});
dt2 << Group Columns("Stats3", {:sports, :countries visited});
// Get groups from dt2
colgroups = dt2 << Get Column Groups Names;
groups = Associative Array();
For Each({groupname}, colgroups,
	groups[groupname] = dt2 << Get Column Group(groupname);
dt << Update(
	With(dt2),
	Match Columns(:name = :name)
Close(dt2, no save);
// add groups back
For Each({{groupname, groupcols}}, groups,
	dt << Group Columns(groupname, groupcols);
