vishwasanj
Update or Match columns from 2 tables
Hi All,
I have 2 data tables, data.jmp and final.jmp
I need to match 2 columns (lot name, wafer number) from data.jmp to 2 columns (LOT, WFR) from final.jmp. I need to create a new subset comparing these 2 tables and output as FINAL_UPDATED data table.
Thank you for the help.
Re: Update or Match columns from 2 tables
What I specified in my last response is exactly what you need to do to put the 2 data tables together, matching upon the 2 pairs of columns you indicated.  Below is the filled out dialog box from
     Tables==>Join
that when executed creates the output table you described.  Attached is the new table created.
Use the pull down menu item
     Tables==>Join
and you will be able to match the columns you need to match and it will generate a new data table
vishwasanj
Thank you txnelson. Maybe I should have explained this more clearly.
Attached are the tables.
data. jmp represents the user input file through .json
Final_table is the final concatenated table.
I want to refine the Final_table according to what I have in the data.jmp table.
Now I want to make a new table Final_Updated by matching LotInfoes.LotName and LotInfoes.Wafers of data.jmp to Lot and wafers of Final_table.jmp (For example, I don't have wafer 1 in the both lots, so my updated table shouldn't have it)
Any suggestions would help me.
     Tables==>Join
vishwasanj
Thank you txnelson
ian_jmp
Level X
In JMP 13 you might also find the virtual join useful.
vishwasanj
Thank you for the idea Ian
