JMP platforms work as they are scripted by the JMP developers. You can make a Wish List change and maybe it will change in the future,
I do not know how to make GraphBuilder do what I think you want unless you restructure your data table. GraphBuilder will not nest different data types, and X-Grouping uses the same X scale.  So the only way to do this is to make each group's (Type) time (X variable) its own column and drag them side by side.  Below is a capture of your table layout and a restructured, Split table: Split  :Time by :Type grouping by :row and keeping all columns.
  Your specified table layout - Row # column added
Your specified table layout - Row # column added Date Split by Type, Grouped by row #
Below is the side-by-side GraphBuilder created with the split table time table
Here is the script.
Graph Builder(
	Variables( X( :BAD ), X( :GOOD ), Y( :y ) ),
	Elements(
		Position( 1, 1 ),
		Points( X, Y, Legend( 19 ) ),
		Smoother( X, Y, Legend( 20 ) )
	Elements(
		Position( 2, 1 ),
		Points( X, Y, Legend( 21 ) ),
		Smoother( X, Y, Legend( 22 ) )
Of course you do not need to restructure, you could create new variables via the transform, a new variable for each type then drag the transfomed variables to the X-Axis, side-by-side
Below is the saved script. Splitting the table will be the easiest, if there are many groups
Graph Builder(
	Size( 856, 534 ),
	Variables(
		X( Transform Column( "Bad[TIME]", Formula( If( :TYPE == "BAD", :TIME ) ) ) ),
		X(
			Transform Column(
				"Good[TIME]",
				Formula( If( :TYPE == "GOOD", :TIME ) )
		Y( :y )
	Elements(
		Position( 1, 1 ),
		Points( X, Y, Legend( 17 ) ),
		Smoother( X, Y, Legend( 18 ) )
	Elements(
		Position( 2, 1 ),
		Dispatch( {}, "Bad[TIME]", ScaleBox, {Format( "m/d/y", 10 )} ),
		Dispatch(
			"Good[TIME]",
			ScaleBox,
			{Format( "m/d/y", 10 ), Min( 3629059200 ), Max( 3629232000 ),
			Interval( "Numeric" ), Inc( 17.28 ), Minor Ticks( 1 )}
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model( 17, Level Name( 0, "y Bad", Item ID( "y", 1 ) ) ),
			Legend Model( 19, Level Name( 0, "y Good", Item ID( "y", 1 ) ) )}
		Dispatch(
			"400",
			LegendBox,
			{Legend Position( {17, [0], 18, [-1], 19, [1], 20, [-1]} ),
			Position( {0, -1, 1, -1} )}
