SW
SW
Uniform axis scaling in Control Chart Builder Script
I am working on a script to cycle through a list of properties and make a pair of control charts for each.  The pair (by "Line") of charts must be displayed side-by-side and have the same Y-axis scaling.
I have a list of properties (a list variable called CCProperty), and a list of axis settings for each property (a matrix variable called CCFormat).  Even though I used the same numbers (as CCFormat[i,j]) for min, max, increment, and number of ticks for each graph, the scales do not consistently match.
Any help would be appreciated. I am using JMP Pro 18.1.1
The full data table with embedded script is attached.  Here's a snippet of the code:
For(i=1, i <= N Items(CCProperty), i += 1,  //  Loop through all the properties and make control charts using the graph min and max
Mainbox<<append(hb=H List Box()); //Append the horizontal box with the two graphs to the mainbox
//*********Generate the Control Chart for LINE 1:**************
	hb<<append(Control Chart Builder(
	Size( 650, 600 ),Graph Spacing( 10 ),
	Test Excluded Subgroups( 0 ),Show Limit Labels( 1 ),Show Capability( 0 ),Show Limit Summaries( 0 ),
	Variables( Subgroup( :Workorder ), Y(column(CCProperty[i])) ),
	Chart(Position( 1 ),Points( Statistic( "Average" ) ),Limits( Sigma( "Moving Range" ), Spec Limits( 1 ) )	),
	Chart(Position( 2 ),Points( Statistic( "Moving Range on Means" ) ),Limits( Sigma( "Moving Range" ) )	),
	Chart(Position( 3 ),Points( Statistic( "Standard Deviation" ) ),Limits( Sigma( "Standard Deviation" ) )	),
	Show Control Panel( 0 ),
	By( :Line ),
	Where( :Line == "Line 1" ),
	SendToReport(Dispatch(CCProperty, ScaleBox,{Min( CCFormat[i,1] ),Max( CCFormat[i,2] ),Inc( CCFormat[i,3] ),Minor Ticks( CCFormat[i,4] )}	),
//*********Generate the Control Chart for LINE 2:**************
	By( :Line ),
	Where( :Line == "Line 2" ),
	SendToReport(Dispatch(CCProperty, ScaleBox,{Min( CCFormat[i,1] ),Max( CCFormat[i,2] ),Inc( CCFormat[i,3] ),Minor Ticks( CCFormat[i,4] )}),
);  //end of For Loop
Re: Uniform axis scaling in Control Chart Builder Script
I did slight changes to your script which might solve the issue in this case. This part I changed the most
	Dispatch({}, CCProperty[i], ScaleBox, {Min(CCFormat[i, 1]), Max(CCFormat[i, 2]), Inc(CCFormat[i, 3]), Minor Ticks(CCFormat[i, 4])}),
View more...
CCProperty = {"Strength", "Elongation", "Weight", "Thickness"};
CCFormat = [60 66 1 4, 25 45.5 5 4, 3.4 4.0 0.1 4, 8 16 1 4];
outputwin = New Window("Control Charts", Outline Box("Control Charts", Mainbox = V List Box()));
For(i = 1, i <= N Items(CCProperty), i++,
	Mainbox << append(hb = H List Box());
	hb << append(
			Size(650, 600),
			Graph Spacing(10),
			Test Excluded Subgroups(0),
			Show Limit Labels(1),
			Show Capability(0),
			Show Limit Summaries(0),
			Variables(Subgroup(:Workorder), Y(Column(CCProperty[i]))),
			Chart(Position(1), Points(Statistic("Average")), Limits(Sigma("Moving Range"), Spec Limits(1))),
			Chart(Position(2), Points(Statistic("Moving Range on Means")), Limits(Sigma("Moving Range"))),
			Chart(Position(3), Points(Statistic("Standard Deviation")), Limits(Sigma("Standard Deviation"))),
			Show Control Panel(0),
			By(:Line),
			Where(:Line == "Line 1"),
	hb << append(
			Size(650, 600),
			Graph Spacing(10),
			Show Capability(0),
			By(:Line),
			Where(:Line == "Line 2"),
Generally I would suggest setting the axis values outside of the graph, but in simple case like this, using sendtoreport inside the graph message should be enough
SW
SW
Thanks for the help!  I guess the missing subscript [i] in my CCProperty list variable was the cause of my issues.
