Level XIII
Undocumented Secrets
hidden secret in JMP: you can paste multiple column names via CTRL+C | CTRL+V
https://community.jmp.com/t5/Abstracts/Plenary-John-Sall-on-Secret-Features-of-JMP/ev-p/849554 @ 44min:
(view in My Videos)
https://community.jmp.com/t5/Abstracts/Advanced-Data-Preparation-10-Essential-Tools-in-JMP-to-Get-Fr... ( @jules )
https://community.jmp.com/t5/Discussions/Possible-to-rename-all-columns-in-a-table-from-a-list/m-p/5...( @txnelson )
edit: removed in JMP19
please vote:
Restore data-grid behavior: Pasting onto column names to rename them
duplicates:
Please restore ability to copy-paste column names from one table to another
Restore Column Name Update Via Paste
[More Topic Containers like this]
28 REPLIES 28
Level XIII
Re: Paste multiple column names
Level XIII
@BHarris  submitted wishes to restore the paste column names functionality:
Level XIII
Level XIII
jcagande
Level XIII
 replacing column names via CTRL+V doesn't work anymore in JMP19
.... but there is a workaround:
a) select columns to rename
b) copy new column names to clipboard
c) Recode Column Names- Only selected columns
d) "Paste Multiple"
JMP19 (c+d): 7 mouse clicks  -  instead of CTRL+V in JMP18
(view in My Videos)
Level XIII
As an alternative, you can link a script to a Keystroke - or run it via the main menu (with 2-3 mouse clicks):
(view in My Videos)
View more...
names default to here(1);
dt = current data table();
cols = dt << get selected columns();
oldColNames = Transform each({col}, cols, col << get name);
newColNames = Words(get clipboard(),"\!n\!t,;");
set clipboard(concat items(oldColNames, "\!t")); // poor man's CTRL + Z
if(!(nitems(newColNames)==nitems(oldColNames)),
	Caption("# colnames doesn't match");
for each(  {col,idx}, cols, col << set name(newColNames[idx]));
Caption (Char(N items(newColNames))  || " column names replaced");
wait(1);
Caption(remove);
Level XIII
Level XIII
Another hidden functionality: edit table scripts by double click
JMP18:
- in the Table Scripts menu, one can double click on a script to open end edit the script
- to change the name of the script,  select it and click again
(view in My Videos)
this is similar to Windows Explorer [sorry, difficult to distinguish Click and double click in the video - just try on your own ...]
(view in My Videos)
JMP 19:
- click + click again: not working anymore
- double click: change the name of the script
- edit the script: only accessible via right click menu : (
I just asked JMP support [TS- ?   ] if the change was intentional ...
(view in My Videos)
Level XIII
Another removed function:
Are Column formulas being evaluated?
check the status bar of the window in front - when JMP is finished, it says : evaluations done
(view in My Videos)
in JMP19, such calculations are secret, JMP is saying "evaluations done" - but evaluations are running in the background.
With a little trick, you can actually get JMP to reveal its secret recalculations:
cols = dt << get column references();
Eval(
	Eval Expr(
		New Column( "recalc",
			Formula(
				If( Row() == 1,
					Sum(
						Transform Each( {col}, Expr( Name Expr( cols ) ),
							Is Missing( col[Row()] )
					Caption( "recalc" );
					Wait( 0 );
(view in My Videos)
