dlifke
Tip: How to force a zero intercept for "Model Coefficients for Original Data" in Partial Least Squares
The problem I had was that I was still getting a non-zero Intercept Coefficient under “Model Coefficients for Original Data” even if I checked No Intercept.  (I did get a zero Intercept Coefficient under “Model Coefficients for Scaled Data.) I found that if I uncheck the “Centering” box when selecting [Personality: Partial Least Squares] it will then give me the desired zero for the Intercept Coefficient under “Model Coefficients for Original Data.”
dlifke
Re: Tip: How to force a zero intercept for "Model Coefficients for Original Data" in Partial Least Squares
