Is there a formula to remove white space from a character field ?
Jun 8, 2016 02:22 PM(16403 views)
Is there a formula to remove white space from a character field. The data field is not supposed to have and white spaces or blank spaces within the field.
Your code will only remove spaces, \s will find all white space in regex including tabs, carriage returns, new lines, and a host of other white space characters.
VinKane : This will work : Name = "Vin Kane" ; regex(Name," ","","globalreplace"); // The first character is white space within quotations , the second character is just quotations without a space ledi.trutna : Trim is not capable of replacing the spaces in between - but like you said it works for leading and trailing white spaces
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '18940' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '18940') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '18940') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
