Dukowitz62
Time Series Forecast - Nothing Happens
In attempting to use Time Series Forecast, after Run, when selecting “Save Results”;  then in the next window checking box with “Save Forecast Results to Original Data Table” results in no columns.  Nothing happens.
Why are no columns appearing?  Do others experience this issue?
Dukowitz62
Re: Time Series Forecast - Nothing Happens
Because we were attempting to forecast for each customer, each with data for each month, it was just not possible to do a time series forecast. We adjusted our approach and were able to successfully get a time series forecast by aggregating individual customers into customer categories by month so that there were unique dates for each customer category.   This also solved the problem posed in my previous post:
https://community.jmp.com/t5/Discussions/Time-Series-Forecasting-Per-Account/m-p/411684
peng_liu
I cannot think of any possible reason. A wild guess is that there are no forecasts. But I still cannot replicate any such case. Please contact JMP Tech Support support@jmp.com
Dukowitz62
peng_liu
Glad that things work out for you, though I still cannot imagine the hurdles that you have while forecasting individual customers.
Use the JMP sample data M3C Quarterly data as an example, think each series is a customer's data. Every series have their own timestamps. Sounds like a similar situation.
Anyway, if forecasting individual customers becomes necessary in the future, please don't hesitate to contact our Tech Support.
