shampton82
This might be a big ask, but can someone help with a script to try and select a normal distribution when it is pretty close to the best fitted distribution?
So here's what I'm hoping for:
When you click fit all in Distribution platform you get a lot of fits
However, if the AICc of the best fit is within 5 of the normal distribution you might as well use the normal fit.  Sooooooo, if there a way to script something that would go through a bunch of columns that have already had the best fit ran and then adjust the selected fit (assuming it is non-normal) to Normal if it is within an AICc of 5 to the normal distribution?  Bonus points would be for being able to have an input box to enter the delta of the AICc you are willing to live with.  Double bonus would be to remove Students t, Cauchy, and ExGaussian from the selection options as you can't calculate process capabilities on these distributions (and that will be the next step to run after this clean up script is ran).
I've tried and can't get it to work, any help would be greatly appreciated!!
Steve
3 ACCEPTED SOLUTIONS
shampton82
Re: This might be a big ask, but can someone help with a script to try and select a normal distribution when it is pretty close to the best fitted distribution?
Okay I got there!  I'm sure it's not very eloquent but I wanted to throw it out there in case it would help anyone else.
The first step is selecting the columns on your data table that you want to fit distributions for.
//rev 8-24-24
names default to here(1);
dt=current data table();
colnames=dt<<Get selected Columns(continuous, "string");
nw=new window("What AICc is comparable?", Show Menu( 0 ), Show Toolbars( 0 ),<<modal,<<size(300,100),<<return results,
			vlistbox(
				hlistbox(
					Text Box("Put in what difference between Normal and the best fit you consider the same"),
					neb1=Number Edit Box(5);
				 Button Box( "OK",var1 = neb1 << Get;)
rpt=new window("test",<<WindowView( "Invisible" ),
		obj=dt<<distribution(column(eval(colnames)),Fit All
Wait( 0 );
dt1=rpt["Distributions", "Compare Distributions", Table Box( 1 )] <<
Make Combined Data Table(invisible);
rpt << Close Window;
//get rid of distribution types that can't have a Process Capability Analysis
// Delete selected rows
dt1 << Select Where(
	:Distribution == "Cauchy" | :Distribution == "ExGaussian" | :Distribution ==
	"Student's t"
) << Delete Rows;
//creat a column that will identify the order of the fitted distributions
// New column: Column 10
dt1 << New Column( "Column 10",
	Numeric,
	"Continuous",
	Format( "Best", 12 )
// Change column formula: Column 10
dt1:Column 10 << Set Formula( Col Cumulative Sum( 1, :Y ) );
//Select the best fit as well as the normal fits for all Y's then deleted all other rows
dt1 << Select where(
	:Distribution == "Normal" | :Column 10 == 1
) << Invert Row Selection << Delete Rows;
//Create columns to determien and select the normal fit (if it is the best fir or withing our delta criteria we input at the start)
dt1 << New Column( "Column 11",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula( If( :Column 10 == 1, Empty(), :AICc - Lag( :AICc, -1 ) ) )
dt1 << New Column( "Column 12",
		Numeric,
		"Continuous",
		Formula( If( :Distribution == "Normal" & :Column 10 == 1, 1 ) )
eval(eval expr(dt1 << New Column( "Column 13",
		Numeric,
		"Continuous",
		Formula(
			If( :Column 10 == 1 & :Distribution != "Normal",
				If( Abs( Lag( :Column 11, -1 ) ) > expr(var1),
					1
dt1<<	New Column( "Column 14 2",
		Numeric,
		"Continuous",
		Formula(
			If( Is Missing( Col Maximum( :Column 13, :Y ) ) & :Column 10 == 2,
				1
		Set Selected
dt1 << New Column( "Column 14",
		Numeric,
		"Continuous",
		Formula( Sum( :Column 12, :Column 13,:Column 14 2 ) ),
		Set Selected
wait(0);
// Delete column formula: Column 10
dt1:Column 10 << Delete Formula;
// Delete column formula: Column 11
dt1:Column 11 << Delete Formula;
dt1:Column 12 << Delete Formula;
dt1:Column 13 << Delete Formula;
dt1:Column 14 << Delete Formula;
//Delete non-Normal fits that are wihtin our criteria
dt1 << Select Where( :Column 14 == 1 ) <<
//Puts all the Y's and distributiosn into lists
col={};
dist={};
for each row(dt1,
		insertinto(col,:Y);
		insertinto(dist,:Distribution);
close(dt1, nosave);
//bring back up the distribution platform but only with the Y's that we could fit a distribution to
rpt=new window("Best Distribution",
		obj=dt<<distribution(column(eval(col)),Process Capability( 0 ),
//Apply the distributions
for(i=1, i<=n items(col), i++,
	//whatbox = column(colnames[i])<<get name;
	//test=(Report(obj) << XPath( "//OutlineBox[text() = '"||col[i]||"']"))<< get title();
	//if(eval(test[1])==eval(col[i]),
		if(dist[i]=="Normal",obj[i]<< Fit Normal);
		if(dist[i]=="Exponential",obj[i]<< Fit Exponential);
		if(dist[i]=="Gamma",obj[i]<< Fit Gamma);
		if(dist[i]=="Johnson Su",obj[i]<< Fit Johnson);
		if(dist[i]=="Lognormal",obj[i]<< Fit Lognormal);
		if(dist[i]=="Normal 2 Mixture",obj[i]<<Fit Normal 2 Mixture);
		if(dist[i]=="Normal 3 Mixture",obj[i]<<Fit Normal 3 Mixture);
		if(dist[i]=="SHASH",obj[i]<< Fit Shash);
		if(dist[i]=="Weibull",obj[i]<< Fit Weibull);
		if(dist[i]=="ZI SHASH",obj[i]<< Fit ZI SHASH);
		if(dist[i]=="Beta",obj[i]<< Fit Beta;);
Thanks for the inspiration @jthi and @txnelson (I used a bunch of your other posts to help me get here)
Nice job.
I went through your script and have made a few changes.
  1. I changed the syntax of the creation of Column 10 to be the same as the syntax used for column, Column 11 - Column 14.  I suggest that you change the names you are using.  The current names, Column 10 etc. is a name that JMP uses when it is creating columns and needs a default column name.  Therefore, there is a good chance that a data table you are going to run your script on may have a column by one of the names you are using.  My suggestion is to simply change Column 10 etc. to _Column 10_ etc. to avoid the issue.
  2. I changed your New Column code from specifying a Formula, to using Set Each Value.  It provides the same functionality, but without creating a formula, which your code ends up having to delete.
  3. I eliminated a For Each Row that you are using to create the lists, col and Dist.  This can be done in single statements, thus eliminating the need to loop through the data table
  4. I also suggest that you put in a check at the beginning of your code to determine if there are actually selected columns, and if not, display a message telling the user to select columns and run the script again..
See my changes below
//rev 8-24-24
			vlistbox(
				hlistbox(
Wait( 0 );
	"Student's t"
) << Delete Rows;
	Numeric,
	"Continuous",
dt1:Column 10 << Set Formula*/
	Set Each Value( Col Cumulative Sum( 1, :Y ) );
		Numeric,
		"Continuous",
		Set Each Value( //Formula(
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
					1
		Numeric,
		"Continuous",
				1
		Set Selected
		Numeric,
		"Continuous",
		Set Selected
wait(0);
dt1:Column 14 << Delete Formula;*/
/*dt1 << Select Where( :Column 14 == 1 ) <<
Invert Row Selection << Delete Rows;*/
dt1 << delete rows( dt1 << get rows where( :Column 14 != 1) );
/*col={};
dist={};
for each row(dt1,
		insertinto(col,:Y);
col = dt1:Y << get values;
dist = dt1:Distribution << get values;
close(dt1, nosave);
Here is my approach based on your script
dt = Open("$SAMPLE_DATA/Cities.jmp");
NON_VALID_DIST = {"Cauchy", "ExGaussian", "Student's t"};
If(N Table() == 0,
	Throw("No tables open");
colnames = dt << Get selected Columns(continuous, "string");
If(N Items(colnames) == 0,
	Throw("No continuous columns selected");
nw = New Window("What AICc is comparable?", Show Menu(0), Show Toolbars(0), <<modal, <<return result,
	H List Box(
		Panel Box("Options",
			Lineup Box(N Col(2),
				Text Box("Put in what difference between Normal and the best fit you consider the same", << Set Wrap(200)),
				neb = Number Edit Box(5)
		Panel Box("Actions",
			Lineup Box(N Col(1),
				Button Box("OK"),
				Button Box("Cancel")
If(nw["Button"] != 1,
	Throw("Cancelled");
Caption("Please wait, calculating fits");
same_limit = nw["neb"];
dist = dt << distribution(Column(Eval(colnames)), Fit All, Invisible);
dt_fits = Report(dist)[Outline Box("Compare Distributions"), Table Box(1)] << Make Combined Data Table(invisible);
dist << Close Window;
dt_fits << Get Rows Where(Contains(NON_VALID_DIST, :Distribution));
dt_fits << Delete Rows;
// Leave only the lowest AIC and normal distribution
rows_to_delete = dt_fits << Get Rows Where(!(:Distribution == "Normal" | Col Rank(:AICc, :Y) == 1));
dt_fits << Delete Rows(rows_to_delete);
//"Fix" Johnsons to Johnson
For Each Row(dt_fits,
	If(Starts With(:Distribution, "Johnson"),
		:Distribution = "Johnson";
// Could also store AIC for normal and other distribution (if available) to aa_y if needed
aa_y = Associative Array(Column(dt_fits, "Y"));
For Each({ycol}, aa_y << get keys,
	yrows = Loc(dt_fits[0, "Y"], ycol);
	If(N Items(yrows) > 1, // Normal isn't the only distribution
		If(dt_fits[yrows[2], "AICc"] - same_limit <= dt_fits[yrows[1], "AICc"],
			aa_y[ycol] = "Normal";
			aa_y[ycol] = dt_fits[yrows[1], "Distribution"];
Close(dt_fits, No save);
dist = dt << Distribution(
	Column(Eval(aa_y << get keys)),
	Process Capability(0),
	Invisible
For Each({{col, best_dist}, idx}, aa_y,
	Eval(Substitute(
		Expr(dist[idx] << _fit_),
		Expr(_fit_), Parse("Fit " || best_dist); // I hate using Evil Parse, but in this case it might work as long as you "fix" Johnson fits
dist << Show Window(1);
Caption(Remove);
Write();
I would also consider creating the first distribution for best fits one column at the time. This way you could update the caption after each column as calculating the best fit can take a long time (could also consider updating progress bar).
15 REPLIES 15
Is the Distribution platform still open and it has all the results or where are the results stored? Do you need to leave compare distributions open or is it enough that one distribution has been fit?
shampton82
Hey @jthi !
Yeah the platform would still be open and all the best fit comparisons are still there.  I think ideally the comparison box is still there but I can live with just the best fit if that is a lot easier.
So starting here
and for something like this fit, normal would be chosen, however lets say that Normal was way down the list, then SHASH would be chosen
Here normal would be chosen as it is within 5 of Johnson Sb's AICc value.
Hope this helps and thanks for looking at this!
Steve
There are two difficult things with this which are related: you cannot default sort table box with JSL (to my knowledge and this causes issues in many platforms) and this makes it difficult to set the check boxes correctly (they are not in same order as you see other values, most likely they don't get always sorted or something)
And because of this, I'm not sure if this will work in every case (I tried doing without the For but the orders did change too much)
dt << Distribution(
	Continuous Distribution(Column(:"pop- m"n), Process Capability(0)),
	Continuous Distribution(Column(:POP), Process Capability(0)),
	Continuous Distribution(Column(:Max deg. F Jan), Process Capability(0)),
	Continuous Distribution(Column(:OZONE), Process Capability(0)),
	Continuous Distribution(Column(:CO), Process Capability(0)),
	Continuous Distribution(Column(:SO2), Process Capability(0)),
	Continuous Distribution(Column(:NO), Process Capability(0)),
	Continuous Distribution(Column(:PM10), Process Capability(0)),
	Continuous Distribution(Column(:Lead), Process Capability(0)),
	Continuous Distribution(Column(:X), Process Capability(0)),
	Continuous Distribution(Column(:Y), Process Capability(0)),
	Fit All
// Script basically starts from here
obs = Current Report() << XPath("//OutlineBox[@helpKey='Distrib']");
If(N Items(obs) > 0,
	dist = obs[1] << Get Scriptable Object;
obs = Report(dist) << XPath("//OutlineBox[text()='Compare Distributions']");
For Each({ob}, obs,
	tb = ob[TableBox(1)];
	vals = tb << get;
	// Order might be incorrect in these
	dists = vals["Distribution"];
	normal_idx = Contains(dists, "Normal");
	normal_aic = vals["AICc"][normal_idx];
	m_aic = Matrix(vals["AICc"]);
	// This comparison might require some fixes
	ifs = (ob << parent) << XPath("//IfBox");
	Remove From(ifs, 1, 2); // might require more robust method
	fit_titles = (ifs << child) << get title;
	If(Min(m_aic) >= normal_aic - 20 & normal_idx > 1,
		For(i = 1, i <= N Items(dists), i++,
			tb[1] << Set All(0);
			tb[1] << Set(i);
			idx = Contains(ifs << get, 1);
			If(fit_titles[idx] == "Fitted Normal Distribution",
				break();
Write();
shampton82
Thanks for the script @jthi !
I tried running it and got this error
From the log:
Subscript Range in access or evaluation of 'fit_titles[ /*###*/idx]' , fit_titles[/*###*/idx]
at line 54 in C:\Users\steve.hampton\OneDrive - Precision Castparts Corp\Documents\Script 3.jsl
You have to start adding debug prints and check where it goes wrong. You might have to change the loop from N Items(dists) to N Items(fit_titles) or something.
I attempted to approach the solution similar to Jarmo's, but different.  Different in that I chose to use the Check Boxes in the Table Box under the Compare Distributions Outline Box.  I reasoned (correctly), that if the Normal AICc was within 5 of whatever the actual selected distribution was, then all that needs to be done is in the JSL is to unselect the check box for the JMP chosen distribution, and to select the check box for the Normal Distribution.  If in JSL, this unselection and selection is made, the correct distribution is displayed on the Histogram.  However, it appears that the normal messages that are used to manipulate a check box from within JSL do not return or set check boxes correctly........unless I do not have a complete understanding of the checkboxes displayed in a table box.
See below for what I found
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
		Column( :INM2 ),
		fit all(1)
// From the current report, find all of the Compare Distribution boxes
//dist =( current report() << xpath( "//OutlineBox[text()='Compare Distributions']" ));
// There is a bug in JMP where the check boxes return a standard order, not the order displayed
checkBoxOrder = {
		"Normal",
		"Cauchy",
		"Student's t",
		"Lognormal",
		"Exponential",
		"Gamma",
		"Johnson Sb",
		"SHASH",
		"ExGaussian",
		"Normal 2 Mixture",
		"Normal 3 Mixture",
		"Weibull"
distr = dist<<report;
// The Johnson Sb returns the Fit All as the selected distribution
// However, if one gets all of the selected indices for the
// check boxes, it indicates that the 7th check box is selected
mat=distr[1][CheckBoxBox(1)]<<get selected indices as matrix;
show(mat);
// I am not sure if this is just a false artifact, but if one
// looks into the checkBoxOrder list, the 7th item is Johnson Sb
show(checkBoxOrder[loc(mat,1)]);
// However, if one wants to unselect the Johnson Sb check box
// it is the 9th check box item that has to be selected
distr[1][CheckBoxBox(1)]<<set(9,0);
// Setting the 7th check bos as selected selects the Normal
// destribution
distr[1][CheckBoxBox(1)]<<set(7,1);
// or
// Setting the loc CheckBoxOrder index value will set the
// Normal distribution to seelcted
// distr[1][CheckBoxBox(1)]<<set(loc(mat,1), 1 );
// If column PNP3 is selected the same patterns appear
// The selected distribution is LogNormal
// The get selected indices as matrix return with the
// 4th element set as 1
// If you set specify <<set(4,1) the Normal Distribution is selected
// but to turn off the LogNormal selection the 8th checkbox needs
// to be set to 0
I am hoping that someone can clue me in as the my error in logic or usage.  If no such enlightenment is available, I will turn this over to JMP Support.
My guess is that the checkboxes aren't really tied to the table box -> when you sort the table box, check boxes do not get sorted properly. And then by default the table box is already sorted in different manner than "default". So you end up in very weird situation where you have no idea which index sets which item as they are not aligned. That is why I went with the very complicated For loop and to check which distribution's Ifbox was enabled.
If you use "default" order (which you cannot set with JSL which causes issues in other platforms also like process screening) you get this
these are the "correct" indices most often.
I haven't yet tried if you could calculate which index is which given the current sort order (or with the knowledge which column was used for sorting).
shampton82
Hey @jthi ,
Thanks again for taking a crack at this(and @txnelson )!  I've been playing around with the code and it works pretty well most the time.  Since it seems like the issue is the way the Compare Distributions behaves with the ordering, I think that if I don't care about having all the distributions still there something like this should work: Run the distribution platform and fit all, then make a combined data table of the compare distribution outputs, in the new table remove the three distributions that can't be used for a process capability, then do the comparison on the distributions for the AICc of the top fit vs where normal lands, then take the top fit or the normal fit for each variable and delete all the rest(thus making this table a distributions property table), then use the manage limits platform to apply those distributions as a column property on the main table and finally relaunch the distribution platform.  I'm hoping to give it a shot this weekend and see if it would work.
Steve
That was my original idea and that is why I asked if you did want to keep the Compare Distributions so I went with that. As long as you can keep the names same between different platforms it should work fine.
