Okay I got there!  I'm sure it's not very eloquent but I wanted to throw it out there in case it would help anyone else.
The first step is selecting the columns on your data table that you want to fit distributions for.
//rev 8-24-24
names default to here(1);
dt=current data table();
colnames=dt<<Get selected Columns(continuous, "string");
nw=new window("What AICc is comparable?", Show Menu( 0 ), Show Toolbars( 0 ),<<modal,<<size(300,100),<<return results,
			vlistbox(
				hlistbox(
					Text Box("Put in what difference between Normal and the best fit you consider the same"),
					neb1=Number Edit Box(5);
				 Button Box( "OK",var1 = neb1 << Get;)
rpt=new window("test",<<WindowView( "Invisible" ),
		obj=dt<<distribution(column(eval(colnames)),Fit All
Wait( 0 );
dt1=rpt["Distributions", "Compare Distributions", Table Box( 1 )] <<
Make Combined Data Table(invisible);
rpt << Close Window;
//get rid of distribution types that can't have a Process Capability Analysis
// Delete selected rows
dt1 << Select Where(
	:Distribution == "Cauchy" | :Distribution == "ExGaussian" | :Distribution ==
	"Student's t"
) << Delete Rows;
//creat a column that will identify the order of the fitted distributions
// New column: Column 10
dt1 << New Column( "Column 10",
	Numeric,
	"Continuous",
	Format( "Best", 12 )
// Change column formula: Column 10
dt1:Column 10 << Set Formula( Col Cumulative Sum( 1, :Y ) );
//Select the best fit as well as the normal fits for all Y's then deleted all other rows
dt1 << Select where(
	:Distribution == "Normal" | :Column 10 == 1
) << Invert Row Selection << Delete Rows;
//Create columns to determien and select the normal fit (if it is the best fir or withing our delta criteria we input at the start)
dt1 << New Column( "Column 11",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula( If( :Column 10 == 1, Empty(), :AICc - Lag( :AICc, -1 ) ) )
dt1 << New Column( "Column 12",
		Numeric,
		"Continuous",
		Formula( If( :Distribution == "Normal" & :Column 10 == 1, 1 ) )
eval(eval expr(dt1 << New Column( "Column 13",
		Numeric,
		"Continuous",
		Formula(
			If( :Column 10 == 1 & :Distribution != "Normal",
				If( Abs( Lag( :Column 11, -1 ) ) > expr(var1),
					1
dt1<<	New Column( "Column 14 2",
		Numeric,
		"Continuous",
		Formula(
			If( Is Missing( Col Maximum( :Column 13, :Y ) ) & :Column 10 == 2,
				1
		Set Selected
dt1 << New Column( "Column 14",
		Numeric,
		"Continuous",
		Formula( Sum( :Column 12, :Column 13,:Column 14 2 ) ),
		Set Selected
wait(0);
// Delete column formula: Column 10
dt1:Column 10 << Delete Formula;
// Delete column formula: Column 11
dt1:Column 11 << Delete Formula;
dt1:Column 12 << Delete Formula;
dt1:Column 13 << Delete Formula;
dt1:Column 14 << Delete Formula;
//Delete non-Normal fits that are wihtin our criteria
dt1 << Select Where( :Column 14 == 1 ) <<
//Puts all the Y's and distributiosn into lists
col={};
dist={};
for each row(dt1,
		insertinto(col,:Y);
		insertinto(dist,:Distribution);
close(dt1, nosave);
//bring back up the distribution platform but only with the Y's that we could fit a distribution to
rpt=new window("Best Distribution",
		obj=dt<<distribution(column(eval(col)),Process Capability( 0 ),
//Apply the distributions
for(i=1, i<=n items(col), i++,
	//whatbox = column(colnames[i])<<get name;
	//test=(Report(obj) << XPath( "//OutlineBox[text() = '"||col[i]||"']"))<< get title();
	//if(eval(test[1])==eval(col[i]),
		if(dist[i]=="Normal",obj[i]<< Fit Normal);
		if(dist[i]=="Exponential",obj[i]<< Fit Exponential);
		if(dist[i]=="Gamma",obj[i]<< Fit Gamma);
		if(dist[i]=="Johnson Su",obj[i]<< Fit Johnson);
		if(dist[i]=="Lognormal",obj[i]<< Fit Lognormal);
		if(dist[i]=="Normal 2 Mixture",obj[i]<<Fit Normal 2 Mixture);
		if(dist[i]=="Normal 3 Mixture",obj[i]<<Fit Normal 3 Mixture);
		if(dist[i]=="SHASH",obj[i]<< Fit Shash);
		if(dist[i]=="Weibull",obj[i]<< Fit Weibull);
		if(dist[i]=="ZI SHASH",obj[i]<< Fit ZI SHASH);
		if(dist[i]=="Beta",obj[i]<< Fit Beta;);
Thanks for the inspiration @jthi and @txnelson (I used a bunch of your other posts to help me get here)
