JustinLin
The gap between graph builder can not eliminate
I meet some problem can't solve by myself. The part of my code is as below.
Graph Builder(
	Variables( X( :DQ_Read_Right ), Group Y( :PCB ) ),
	Elements( Histogram( X, Legend( 4 ), Means and Std Devs( 1 ) ) ),
	Column Switcher( :DQ_Read_Right, {:DQ_Read_Left, :DQ_Read_Right} ),
	Column Switcher( :PCB, {:Vendor, :CPU, :DRAM, :Temp, :V_level, :PCB} ),
		Dispatch({},"DQ_Read_Right",ScaleBox,{Inc( 2 ),Minor Ticks( 1 )}),
		Dispatch({},"DQ_Read_Left",ScaleBox,{Inc( 2 ),Minor Ticks( 1 )})
TheDQ_Read_Left data is ok, but theDQ_Read_Right side data has gaps between the bar. Does anyone know what is the problem?
Even If I modify Inc() in my script, it will ok in the first time, but when I choose another column switcher and click back. The inc() will change from inc(2) to in (1). The process I show in below gif link.
BTW, my system is using Mac OS.
