So, I have a corpus with thousands of documents which contains the details of problems that have been solved in the past. It's a vast pile of knowledge. Each document also has metadata (dubious quality+omissions). The documents have 100+ tokens that tell the story of what was done.
Imagine this use case: through filters and metadata, i've found a document (ID#5678) that is pretty close to the problem that I am trying to solve now. How can I easily find all the documents that are similar to #5678?
With my current knowledge of the Text Explorer platform, I could do a Topic Analysis, then lookup which topic #5678 belongs to (say#10), then look at all the documents where Topic=10.
Is there a better way to do this?
Thanks in advance from stormy Kuala Lumpur, Malaysia!
