Mila
Temperature Profile - visualization
Hi Guys,
Could you please advice, how I can create below graph:
I have been looking into graph builder but no luck.
Thank you in advance
Temperature PROFILETemperature PROFILE
Craige_Hales
Re: Temperature Profile - visualization
If you have the existing graph in JMP, use the red triangle menu and either redo->relaunch->OK to see the interactive builder, or save script to script window to get a script to reproduce it.
In Graph Builder, starting from scratch, drag variables to the drop zones and pick the heat map style (and turn off the other styles if dots are showing up.)
Graph BuilderGraph Builder
this script builds a test table and runs a graph builder script. Using ordinal for pen and date makes the axes behave the way you expect.
dt = New Table( "Untitled 2",
	Add Rows( 0 ),
	New Column( "date", Numeric, "ordinal", Format( "y/m/d", 12 ) ),
	New Column( "pen", Numeric, "ordinal", Format( "Best", 12 ) ),
	New Column( "location", Character, "Nominal" ),
	New Column( "temp", Numeric, "Continuous", Format( "Best", 12 ) )
For( t = Today(), t <= Today() + In Days( 10 ), t += In Days( 1 ),
	For( p = 1, p <= 20, p += 2,
		For( io = 0, io <= 1, io += 1,
			dt << addrows( 1 );
			dt:date = t;
			dt:pen = p;
			dt:location = If( io, "inside", "outside" );
			dt:temp = p + 10 * io + Random Integer( 0, 9 );
dt << Graph Builder(
	Size( 476, 580 ),
	Show Control Panel( 0 ),
	Variables( X( :date ), Y( :pen ), Group Y( :location ), Color( :temp ) ),
	Elements( Heatmap( X, Y, Legend( 42 ) ) )
Heat mapHeat map
Craige
Mila
Thank you very much for helping me out.
I struggle with pen numbers: my data loggers were allocated outside of pens : 1,4,6,8,10,11,13,15,17 and 20.
Could you please let me know how to present only this pens on Y axis.
I have been trying to do this in axis settings but no luck..
Craige_Hales
try making pen (and probably date as well) ordinal.
click the icon to change the modeling typeclick the icon to change the modeling type
After deleting pens 3 and 5 I get this axis
3 and 5 are gone3 and 5 are gone
I think you are still using the continuous modeling type.
Craige
