fishguy
Histograms in graph builder
Hi!
How do I add the count axis on the left of the histogram when created in graph builder?  Also, if I create a histogram using the distribution analysis tool, how do I move the count axis from the right to the left?
Thanks!
Re: Histograms in graph builder
In the Distribution platform, look under the red-triangle menu for Display Options > Axes on Left.
The Graph Builder histogram element has new options for Count and Percent axes coming in JMP 15.  I don't think there is an option for earlier versions of JMP.
fishguy
Thank you!
