Assaf1
Table summary for out of spec
I have table with many columns with spec limits as properties.
How can I create table of % out of spec per column.
If possible with option as table summary (to define the groups) and the new column will be %OOS.
* Or three column: below LSL, above USL and total outside (as the "long term Sigma" table in the tribution plot)
Thanks in advance!
Assaf
Re: Table summary for out of spec
Try this script, it produces the following output
Here is the script
dt = Open( "$SAMPLE_DATA\Semiconductor Capability.jmp" );
// Get all of the continuous columns
colList = dt << get column names( string, continuous );
// For use as an example, delete some spec limits
For( i = 3, i <= N Items( colList ), i = i + 6,
	Column( dt, colList[i] ) << delete property( "Spec Limits" )
// Create the Process Capability Summary Report
PC = Process Capability(
	invisible,
	Process Variables( Eval( colList ) ),
	Spec Limits Dialog( "No (skip columns with no spec limits)" ),
	Capability Box Plots( 0 ),
	Within Sigma Summary Report( 1 ),
	Goal Plot( 0 ),
	Capability Index Plot( 0 )
// Get a list of columns processed
processedColList = report(PC)["Within Sigma Capability Summary Report"][String Col Box( 1 )] << get;
// Create an output table
dt2 = Report( PC )["Within Sigma Capability Summary Report"][Table Box( 1 )] << make into data table( invisible );
PC << close window;
// Create a new column that will allow the original order
// of the columns to be listed
dt2 << New Column( "roworder" );
// Process through the data table, and if the column is not found
// in the processed data, add it to the data table
For( i = 1, i <= N Items( colList ), i++,
	If( N Rows( Loc( ProcessedColList, colList[i] ) ) == 1,
		dt2:roworder[Loc( ProcessedColList, colList[i] )[1]] = i,
		dt2 << add rows( 1 );
		dt2:Process[N Rows( dt2 )] = colList[i];
		dt2:roworder[N Rows( dt2 )] = i;
// Sort the data into the original order
dt2 = dt2 << sort( by( :roworder ), order( ascending ), replace table( 1 ) );
// Get rid of the no longer needed roworder column
dt2 << delete columns( "roworder" );
// Create the new report
nw = New Window( "Summary Report", <<journal, ob = Outline Box( "Within Sigma Capability Summary Report" ) );
dt2 << journal;
close(dt2,nosave);
Assaf1
With few modifications it's work fine
Thanks for the fast and great support!
Assaf
Col_names = Current Data Table() << Get Column Names();
Num_of_cols = N Items( Col_names );
columnsWithLimList = {};
For( i = 1, i <= Num_of_cols, i++,
	Spec_Lims = Column( Char( Col_Names[i] ) ) << Get Property( "Spec Limits" );
//Spec_USL_num = Num (Word(1,Word (2,Char(Spec_Lims[2]),"("),")"));
	//Spec_LSL_num = Num (Word(1,Word (2,Char(Spec_Lims[1]),"("),")"));
	If( //is missing (Spec_USL_num)!=0 || is missing (Spec_LSL_num)!=0,
		Is Empty( Spec_Lims )
		Continue()
	Insert Into( columnsWithLimList, Char( Col_Names[i] ) );
PC = Expr(
	"Process Capability(
invisible,
Process Variables( "
For( i = 1, i <= N Items( columnsWithLimList ), i++,
	PC = PC || ",:" || Char( columnsWithLimList[i] )
PC = PC ||
Goal Plot( 0 ),
Eval( Parse( PC ) );
mkennke
if I understand you right, then you only need to use the Analyze>>Quality and Process>>Process Capability.
Within this report you have to select the summary reports. The summary report contains the requested data. If not, you have to customize it by hand with a right click on the table header. Under "Columns" there are all possible options. If you like you can convert this into a new data table.
Grüße,
Marvin
Assaf1
Thanks for your support!
this option indeed can support with my request.
But (and I don't mention it in the beggining), I've many columns and for some there are no limits - so the process capability not support unless I add the limits.
I'm loking for (probably) JSL that will replace the summary table and when parameter w/o limit - will return empty cell (".")
Here is the script
	invisible,
	Goal Plot( 0 ),
PC << close window;
dt2 << journal;
close(dt2,nosave);
Assaf1
Assaf
		Continue()
PC = Expr(
invisible,
PC = PC ||
Goal Plot( 0 ),
New to JMP. I see the output form the script will be very useful. The script mentioned on the post is very specific to a specific data table, do you have a scrip which I can select columns for the same analysis. (Spec limits from column properties)
Thanks
