klm123
Swap X and Y axis in Variability Chart
The names of my x-axis variables show up vertically aligned.
I would not want to use 'rotated tick options'. Because this increases the horizontal dimension of the chart in an undesired way.
Instead if I can swap the X and Y axis, then the input variable names will become reader-friendly, without increasing the size of the chart :)
Please refer the image. Sorry, I had to crop the image to avoid publishing company data on public platform.
Thanks,
Kishore
Variability chart - swap X and Y axes.pngVariability chart - swap X and Y axes.png
Thanks,
Kishore
Re: Swap X and Y axis in Variability Chart
I am not sure if this is what you're looking for or not, but you can select Vertical Charts within the Variability platform to swap the axes.
Thanks.
Laura
Use @Laura_Lancaster solution below...not my suggestion
It looks like you could just use Graph Builder and put he axes the way you want them
Thanks.
Laura
My bad on this one, I didn't loot for the obvious before I suggested Graph Builder
klm123
Thank you, Laura! This worked perfect!
Regards,
Kishore
Thanks,
Kishore
kluu
Hello Laura,
I am new with jump and having same issue.  Could you kindly show a detail how to do this?
Thanks,
Khanh
Open your data table.  In Laura's example she used the Big Class data table from the Sample Data Folder available under the Help pull down menu.
Go to
     Analyze=>Quality and Process=> Variability // Attribute Control Chart
In the dialog window that is displayed, select column height for the Y, Response and column age for the X, Grouping and click on OK.
The Output Display window will appear
Click on the red triangle to the left of the title for the outline box titled "Variability Guage Analysis for height" and select "Vertical Charts"
The display will change to a Vertical form
