Kyle_at_ii-vi
Remove checkbox selection in Column Info window
I can't for the life of me find documentation on how to uncheck a box in the column info window through jsl.
I'm trying to set a column data type to "Precision" and I don't want "Keep trailing zeroes" selected.
When I run the code below, "Keep trailing zeroes" is selected by default.
column<<format("Precision",12,2)
Re: Remove checkbox selection in Column Info window
https://www.jmp.com/support/help/en/17.2/#page/jmp/column-messages.shtml?os=win&source=application#w...
col<<Format("Precision", <width>, <decimal places>, <"Use Thousands Separator">, <"Keep Trailing Zeroes">, <"Keep All Whole Digits">)
not exactly sure though what the syntax is to disable it... so I tested few options and this seemed to work
Column(dt, "height")<< Format("Precision", Keep trailing zeroes(0), 7, 1);
