Thank you so much, Victor.
Indeed, changing the S and T actually worked. However, I find it a bit odd that even though I set the limit for substrate conversion to 100%, the predicted values still went above that, reaching up to 230%. In the graph I uploaded earlier, I set the temperature range to 20-60°C since that includes the axial points, and I wanted to see what happens within this range because I actually carried out those reactions. Looking back, I think I should have set this range from the start, but I was worried the software might ask me to perform an axial point below that temperature, which I couldn’t do. Unfortunately, I’ve just realized I could have approached it differently.
