dadagda
Summary table dissociated from the source table?
Hi-
I'm a new JMP user and I've been taking some online tutorials and doing some simple practice with JMP.
Here's a simple question: when I create a summary out of a table (say, I choose to calculate the mean of a column), there's an option where I can choose to link the summary table to the original table.  I checked that, and then I got a new table with the mean of the column.  However, when I modified a number in the source table, it told me that "The source table has changed.  Summary table will be dissociated from it."
I thought if I chose to link the two tables, updating the source table will update the summary table?  Did I miss anything here?
Thank you!
mpb
mpb
Re: Summary table dissociated from the source table?
If you select, exclude, or hide a row in the summary table, the corresponding rows in the original table are selected, excluded or hidden. Same if you change row symbol or color in the summary table.
Jeff_Perkinson
The Summary table is linked for row states only, not auto-updating of calculated values.
Sorry.
-Jeff
-Jeff
dadagda
Hi Jeff
Thank you for the reply!  What did you mean by row states?  I thought you meant that if I remove a row from the source table, the summary table will update the change?  But I just tried and removing a row will also dissociate the summary from the source.
Thank you...
mpb
mpb
Level XI
workaround: use Tabulate.
unfortunately, there is some gap between Tabulate and what is possible via Tables/summary.
  • it's not possible to generate graphs from Tabulate Tables - unless one uses Make Into Data Table ... and loses the interactivity with the main table.
  • Tabulate: no support for multiple response and several other column formats
