pankajsync
Summary datable with comma separated values in Column
I would like to make a summary of table in SHEET1 and include Wafers in it. My desired output column is in SHEET2. I wanted to develop a script which can give me output like SHEET2. Note SHEET2 is summary of SHEET1. In Sheet2, I wanted wafers to be separated by comma. The wafers should be num(right(Wafers,2)) in the SHEET2.
Re: Summary datable with comma separated values in Column
There are quite a few posts about something similar like this. I would suggest using Query function with GROUP_CONCAT,  Similar keys (for some reason the original post has been deleted so that post can be a bit difficult to utilize).
Add Listagg/Concatenate/GROUP_CONCAT to Summary platform remember to kudo this so Summary could do this.
There is also this addin written by me Group Listagg Columns which you might be able to utilize.
