Purpose of this addin is to provide a way for user to create new table with a column(s) of grouped values in similar manner as SQL's listagg. In best case this option would be in JMP's Summary and Split platforms as from time to time I would like to keep some values even if I split or aggregate with Summary. I have created wish list items for both of those Split (wish list) and Summary (wish list) table (I might add feature to this addin which would allow user to do Split and/or Summary with listagg).
GUI:
Resulting table:
Combining previous table with Summary table allows me to see all names and ages for each sex while still seeing means of height and weight:
Options
- Suffix
- Suffix which will be added to columns
- Multiple response
- Used to determine if new columns should have multiple response Modeling Type
You can post improvement ideas here here or in open issue in GitHub - Group Listagg Columns .
This tool is part of JMP-Tools I have been working on for some time now and I will release more Add-Ins when time permits in JMP Community.
