SpannerHead
Summary Table For Earliest Test
I'm creating a summary table for some data whereby a group of wafers were tested more than once.  The data is messy regarding which test iteration a particular parameter was measured.  I want the ultimate table to record only the earliest instance of the test for each wafer/die.  I have a retest iteration column in the table I can use as a subgroup on the table but I don't know how to use that to make the collapse to earliest.  The image below shows a wafer/die combination that tested 4 times.  The parameter of interest was tested on iteration2 and 3 for some and iteration 3 and 4 for another.
Slán
SpannerHead
Re: Summary Table For Earliest Test
Can you provide example dataset? Most likely you can calculate test count for each parameter and then pick 1 from all of the parameters
Given this data table
Using this formula
mat = Matrix( :age ) || Matrix( :height ) || Matrix( :weight );
mat[Loc( mat )[1]];
it has the results
SpannerHead
I got this to work with added columns.
New Column( "Initial LRS2",
	Numeric,
	"Continuous",
	Format( "Best", 12 ),
	Formula(
		If(
			!Is Missing( :LRS2 ) & :RETEST ==
			Col Minimum( :RETEST, :WAFER, :sitex, :sitey ),
			:LRS2
Slán
SpannerHead
If you're looking for a ready-to-use solution, there's a short tutorial on Retest Algorithm of YieldOptiX that shows how to extract the earliest test (or similar operations) without scripting
https://www.youtube.com/watch?v=cv8SBoM15W4
Just thought I’d share in case that approach saves you time
This tutorial explains how easily JMP users can see retest data in their test datalogs by applying the Retest Algorithm from YieldOptiX. No coding needed, modern and intuitive UI. Explore more from YieldOptiX here: https://www.siltest.com/yieldoptix
