Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
I'm creating a summary table for some data whereby a group of wafers were tested more than once. The data is messy regarding which test iteration a particular parameter was measured. I want the ultimate table to record only the earliest instance of the test for each wafer/die. I have a retest iteration column in the table I can use as a subgroup on the table but I don't know how to use that to make the collapse to earliest. The image below shows a wafer/die combination that tested 4 times. The parameter of interest was tested on iteration2 and 3 for some and iteration 3 and 4 for another.
Hi, If you're looking for a ready-to-use solution, there's a short tutorial on Retest Algorithm of YieldOptiX that shows how to extract the earliest test (or similar operations) without scripting
This tutorial explains how easily JMP users can see retest data in their test datalogs by applying the Retest Algorithm from YieldOptiX. No coding needed, modern and intuitive UI. Explore more from YieldOptiX here: https://www.siltest.com/yieldoptix
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '857803' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '857803') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '857803') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
