wyler00
Sum of all rows into a list
I'm trying to take the sum of all of my rows and add it to a list.  So, the sum of row 1 will be item 1, sum of row 2 will be item 2, etc.  Is there an easy way to do this using jsl?
Re: Sum of all rows into a list
Here is one way to do it.  Others may have better methods
dt = Current Data Table();
sumMatrix = [];
For Each( {col}, dt << get column names( string, numeric ),
	sumMatrix = sumMatrix || Col Sum( Column( dt, col ) )
You can also use matrix calculations, below is one option
m = dt << get as matrix;
sums = V Sum(m`);
tolist = As List(sums)[1];
sumMatrix = [];
wyler00
Thank you.  Both of your solutions work great.
sums = V Sum(m`);
