iamericha
Is there an equivalent function to excel's BETA.INV() in JSL?
I'm trying to calculate confidence intervals with the following formula that I use in Excel:
=BETA.INV(alpha/2, x, y -x +1)
I can't seem to find an equivalent function in the scripting index so am not sure if one exists. Any help is appreciated.
MRB3855
Re: Is there an equivalent function to excel's BETA.INV() in JSL?
MRB3855
Hi @iamericha   The Beta Quantile function is what you are looking for.
https://www.jmp.com/support/help/en/17.0/#page/jmp/probability-functions-2.shtml#ww2695691
In addition to @MRB3855 response, I will point you to the Scripting Index
     Help=>Scripting Index=<Beta Quantile
It will give you the definition along with an example
iamericha
Thank you for the screenshot!
iamericha
Thank you!
