Dennisbur
Markers
Hello
I would like to do marker "full" square by row
Actually, I see it works, but I'm getting frame square.
How do I get a full square?
wafer_dt << Select Rows << Select where (:"UNIT_STATUS" == "pass") << Colors ("Light Green") << Markers("square");
I found the code and it is marker 15, but the number doesn't work
Re: Markers
Number seems to work fine here (and I think I have always used numbers unless I need custom markers)
dt << Select Where(:sex == "M") << Colors("Green") << Markers(15) << Clear Select;
Re: Markers
