Alec1293
Students T post HOC test
I am running a mixed model in JMP, there is a three way interaction I am interested in the outcome of, which is the interaction: Location * Date * Treatment. I am looking for differences between locations and treatments on each date but unfortunately I cannot use Test Slices because there are 6 comparison within each day I am interested in.  So what I have to do is use the LSmeans Students T which gives every possible comparison (nearly 400) but I am only interested in what happens within each day (6 each day, 7 days = 42 comparisons) and maybe what happens from one day to the next but not the first day vs. last day.
I am using a bonferroni correction to correct for the multiple comparisons by doing alpha(0.05)/ k (# of comparisons being considered), this provides a corrected p-value for the multiple comparisons.  Which I know protects agains type I error but adds vulnerability to type II error possibility. Is this the best way to go about this?
Thank you for any help.
Alec1293
Re: Students T post HOC test
I believe this correction may be to conservative though, in one case I am correcting for 126 comparisons.  Is there a better correction method I can use for multiple comparisons?
