Step by Step Wrap Text in Tabulate Column Titles
Hello
I'm currently using JMP 19 and  want to be able to get the titles / headers of my columns to be a wrapped text in the Data Input Table screen for the Tabulate section I create.
Would someone know a step by step approach?
For example:
Instead of "Hello World" it becomes,
"Hello
World"
Re: Step by Step Wrap Text in Tabulate Column Titles
You wish to have wrapping somewhere in Tabulate? Could you provide drawn example of what you wish to have?
Level XIII
Maybe a screenshot - indicating what you mean with Data Input Table screen.
the column list on the left?
Below is a screenshot of what I would like to achieve within the Demand Input Table - Tabulated window
Level XIII
I had hoped that adding the wrap to the input table would do the trick, but it didn't.
Tabulate seems to prefer single-line headers. Hard to convince!
On the other hand: has an effect on the  vertical axis - somehow:
dt = New Table( "test",
	Add Rows( 5 ),
	Compress File When Saved( 1 ),
	New Column( "Fixtures& Cables",
	New Column( "Fixture QTY",
	New Column( "EST. SHIP",
New column ("value"), Group Columns( "myGroup", :"Fixtures& Cables"n, 3 ) ); //-------try this: ------------- dt = current data table(); cols= dt << get column references; for each({col}, cols, colname = col << get name; col << set name (substitute(colname, " ", "\!n" ))); // .... no change ...... Tabulate( Add Table( Column Table( Analysis Columns( :"Fixtures&Cables"n, :"FixtureQTY"n, :"EST.SHIP"n ) ) ) );
