ACraig
Graph Builder Dynamic Subtitles
Hello, I was hoping someone could help me figure out how to make it so that the subtitle of my graph would be take the min(:Year) and max(:Year) and use them in the subtitle. So, if the minimum year was 2018 and the maximum was 2025 then the subtitle would be "2018 - 2025".
Re: Graph Builder Dynamic Subtitles
Like this?
dt = Open( "$SAMPLE_DATA/US Regional Population.jmp" );
dt:Year << Data Type( "Numeric" );
dt << Graph Builder(
	Show Control Panel( 0 ),
	Show Subtitle( 1 ),
	Variables( X( :Year ), Y( :Population ), Overlay( :Region ) ),
	Elements( Points( X, Y, Legend( 18 ) ) ),
		Dispatch( {}, "graph 1 title", TextEditBox,
			{Set Text( Char( Col Min( :Year ) ) || " - " || Char( Col Max( :Year ) ) )}
8 REPLIES 8
hogi
Level XIII
min / max form the local data filter - or from the whole data set?
For the Data filter, please have a look at https://marketplace.jmp.com/appdetails/Graph+Builder+Toolbar
One of the shortcuts allows you to use the settings of the data filter as title (not subtitle).
hogi
Level XIII
To make it adjust the subtitle, go to  C:\Users\_username_\AppData\Roaming\JMP\JMP\Addins\hogi.GraphBuilderToolbar\resetAxisLabels.jsl
and change line 36 to
gb[Text Edit Box( 2 )] << Set Text( title ); // was Text Edit Box( 1 )
hogi
Level XIII
And based on the data in the table, it is something like:
Names Default to Here(1);
:Year << data type(numeric);
Graph Builder(
	Show Subtitle( 1 ),
	Elements( Line( X, Y ) )
dt << select  where  (:year < 1950 ) << exclude(1) << select where(0);
myRows=where(dt, not (excluded()));
min = Char(min (dt[myRows,"Year"]));
max = Char(min (dt[myRows,"year"]));
((Current Report() << XPath( "//OutlineBox[@helpKey='Data Filter']" )) << get scriptable object) << Show Subtitle( 1 )  ;
current report()[Text Edit Box( 2 )] << Set Text( min || " — " || max );
ACraig
Hello, sorry for the confusion, I should have been more specific. From the whole data set. As my data set updates, I would want those dates to update as well in the subtitle.
Like this?
	Show Subtitle( 1 ),
ACraig
That worked wonderfully! Thank you so much!
I assume as you are talking about "dynamic" subtitles you mean when using Local Data Filter? You will have to use some script to add << Make Filter Change Handler to your local data filter.
Not sure how robust this example is, but it gives an idea of how to use << make filter change handler
gb = dt << Graph Builder(
	Show Subtitle(1),
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11))),
	Local Data Filter(Add Filter(columns(:height)))
// Reference to filter
ob_filter = (gb << Top Parent) << XPath("//OutlineBox[@helpKey='Data Filter']");
ob_filter = ob_filter[1];
ldf = ob_filter << Get Scriptable Object;
f = Function({a},
	dt = gb << Get Data Table;
	w = ldf << Get where clause;
	If(Is missing(w),
		minval = Col Min(:height);
		maxval = Col Max(:height);
		Substitute Into(w, "Select ", "Get Rows ");
		r = Eval(EvalExpr(Send(dt, Expr(Parse(w)))));
		minval = Min(dt[r, "height"]);
		maxval = Max(dt[r, "height"]);
	title = Eval Insert("^minval^ < height: < ^maxval^");
	gb << Dispatch({}, "graph 1 title", TextEditBox, {Set Text(title)});
rs = ldf << Make Filter Change Handler(f);
f(0); // run once
hogi
Level XIII
related discussion - with similar solutions:
Is it possible to dynamically update "graph title" based item selection in local data filter (includ...
here are wishes to add this feature to JMP - without the need for scripting:
Auto population of title - graph builder
Local Data Filter: option use the selection as graph title
the idea: the user can specify which entries of the data filter are added to the title:
