Register for May 2 Mastering JMP Demo - Circumventing Common Pitfalls in Predictive Modeling
Stacking Columns in Script
jmp_jr
I have a couple of questions about stacking data columns in a script. When I do it manually, I get the following script from JMP:
Data Table( "Untitled 11" ) << Stack(
columns(
:Name( "EFL 20508-17DT_CG_100ms" ),
:Name( "FFL 20508-17DT_CG_100ms" ),
:Name( "EFL 20508-18DT_CG_100ms" ),
:Name( "FFL 20508-18DT_CG_100ms" ),
:Name( "EFL 20508-19DT_NOCG_2" ),
:Name( "FFL 20508-19DT_NOCG_2" )
Source Label Column( "Label" ),
Stacked Data Column( "Data" ),
Number of Series( 2 )
In my script, I have a list variable (MyList1) containing the column names, and I would like to stack those columns using "Multiple Series Stack" to create a new table. Also, for "Number of Series" I would like to include NItems(MyList2). Can someone help me with the syntax?
I think this should work:
StackDT = SplitDT << Stack( Columns( MyList1 ),
Source Label Column( "Source" ),
Number of Series( NItems( MyList2 ) )
but it gives me "Column not found in access or evaluation of 'Bad Argument' " in the log.
chungwei
Staff (Retired)
Re: Stacking Columns in Script
I think
Columns(eval(MyList1))
should work.
You might want to call tech support and report it as a bug, or suggestion.
10 REPLIES 10
chungwei
Staff (Retired)
I think
should work.
jmp_jr
Yes. Evaluating the list does make it work. The list used for "Number of Series" also has to be evaluated.
Thanks for the reply.
pmroz
I have a related question about stacking columns. I have been given an Excel spreadsheet that I need to turn into something useful. The spreadsheet looks like this:
style="font-family: Courier New; font-weight: bold; text-decoration: underline;">IDNo  Ctry
Sub  Sub
Date  Ctry  Sub  Sub
Date  Ctry  Sub  Sub Date
style="font-family: Courier New;">
a123  US
 N              Can
Y    4/1/2010  Braz
Y    3/15/2009
b567  US
Y    5/1/2009  Can
N
Braz  N
c392  US
Y    6/1/2008  Can
Y    3/2/2001  Braz
Y    12/15/2008
etc.
I need to stack the results so they look like this:
Ctry  Sub  Sub Date
a123
US    N
b567
US    Y
5/1/2009
c392
US    Y
6/1/2008
a123
Can
Y    4/1/2010
b567
Can   N
c392
Can
Y    3/2/2001
a123
Braz  Y    3-15-2009
b567
Braz  N
c392
Braz  Y    12/15/2008
In the real table there are about 20 countries going across. Is this something that the STACK command can handle? I.e. instead of just stacking one column, I need to stack three columns at once.
Thanks,
Peter
mpb
mpb
Yes. Look up Multiple Series Stack in the docs. There seems to be a minor bug which results in stacked date columns in multiple series stacking not being formatted as dates so you'll have to apply that format after stacking. Single column stacking of dates does maintain date format. You will also have to clean up some extra columns that result from the stacking.
pmroz
Thanks that worked perfectly! This will save us a tremendous amount of time.
Maybe I can append a further question:
I want to stack several columns, column wise. This is easy going the menu way - simply by unchecking 'Stack by Row'. But I have not found an equivalent option on the stack scripting command.
Is it intended to go the cumbersome way to first create a transposed intermediate table, and then applying the stacking on that one?
Regards,
esa
Jeff_Perkinson
You simply add "Stack By Row(0)" to your Stack message. Here's an example:
Data Table( "Solubility" ) << Stack(
columns(
:Name( "1-Octanol" ),
:Ether,
:Chloroform,
:Benzene,
:Carbon Tetrachloride,
:Hexane
Stack By Row( 0 )
-Jeff
Glad to here that. I expected something like this, but was unable to retrieve this information from anywhere within the documentation.
Thank you.
Jeff_Perkinson
I'm glad that will help.
In a case like this, it's easiest to perform the action interactively by clicking and then examine the "Source" script in the resulting table.
Jeff
-Jeff
