Spinning a Scatterplot 3D
I have a point cloud created in the JMP Scatterplot 3D platform.
Two question: I want to drive the rotation using JSL so that it only rotates around the Z axis.
How do I do that?
I want to save the result as an video.
How do I do that?
Thanks, Al Best
founder of the JMP training curriculum
rabelardo
Re: Spinning a Scatterplot 3D
I, too, would like to know how this can be achieved.
Also, how can I make the 3d scatterplot rotate left to right and disable the up and down tilting - something like a navigation control (is this doable within the 3d scatterplot platform?).
Thanks.
- Randy, JMP newbie
- Randy
Here is the example script from the Help==>JMP Scripting==>Scatterplot 3D==>Frame3D==>Set Spin    that demonstrates how to spin the graph using JSL.  As far as making a video, There is shareware that will record to video the activity in a displayed window.  You may want to try      CamStudio - Free Screen Recording Software
dt = Open( "$SAMPLE_DATA/Iris.jmp" );
obj = Scatterplot 3D(
       Y(
              :Sepal length,
              :Sepal width,
              :Petal length,
              :Petal width
obj << Frame3D(
       Set Rotation( -60, -3, 35 ),
       Set Oscillation( -54, 0, 38, 100 )
rabelardo
Thanks so much, Jim !
I prefer the Set Spin command since the graph will rotate continuously (though it would be nice if there's a way to manipulate the speed or duration like that of the Set Oscillation command).
I will now consult the Help > Scripting Index as my guide.
Again, much appreciated !
- Randy, JMP newbie
- Randy
