th20180
Change the font of x-axis label
As attached picture shows, I can't change the font of label (date). Can someone tell me how to change it? Thank you.
ron_horne
Re: Change the font of x-axis label
hi th20180​,
there are two general ways of doing it using the GUI.
first: just change it once by right clicking on the axes title and then on "font"
second: you can change the default by clicking File>>> preferences >> Fonts:
best,
ron
ron_horne
hi th20180​,
best,
ron
th20180
Thank you so much!
