Spec Limit
I would like to ask if I set a particular column with spec limit(eg. low:100 and max:1000), from this limit set how can I create a corresponding column say Pass/Fail column to label those data within limit as Pass and out of spec as Fail.
Thank you.
here some best live sex cam sites: Dildo Cams, Ebony Cams, Couples Cams
Re: Spec Limit
You could create formula like this:
spec = :param << Get Property("Spec Limits");
If(:param < spec["LSL"] | :param > spec["USL"],
	"FAIL",
	"PASS"
but depending on how your data is structured and what you want to do, this might not be the best solution. Attached datatable should have the formula already there
