WebDesignesCrow
How to select & delete rows when the cell did not start with W
I have a table with 2 columns (Process & MC)
I want to select and delete rows that fulfill 2 conditions below using scripting ;
1. Column Process = WB
2. Column MC = does not start with "W"
I've checked through the scripting help but couldn't find anything useful.
If I use below script, it will delete all rows that MC column cells starts with "W"  which is not what I want.
dt3 << select where(:Process == "WB") & Starts With(:MC, "W") << delete rows ;
I'm using JMP 15.
Any idea how to do it?
Re: How to select & delete rows when the cell did not start with W
You are were close. Just combine both conditions inside Select Where and it should work
dt3 << select where(:Process == "WB" & Starts With(:MC, "W")) << delete rows ;
