Created:
Aug 4, 2022 10:42 AM
| Last Modified: Jun 8, 2023 2:10 PM(2637 views)
I have generated a fast flexible space filling design and had a few questions about the output. I was wondering what the discrepancy measure metric was measuring? Additionally, what does the MaxPro column at the bottom of the page indicate?
Created:
Aug 4, 2022 11:16 AM
| Last Modified: Aug 4, 2022 8:23 AM(2617 views)
| Posted in reply to message from JMpuse1 08-04-2022
The discrepancy measure is a relative measure of the quality of a space filling design solution. It is useful when comparing two or more space filling designs. A smaller discrepancy indicates a better design.
Discrepancy is the difference between the design points (which have an empirical uniform distribution) and a theoretical uniform distribution.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '530383' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '530383') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '530383') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
