shampton82
Sizing input boxes
I made a script to line up columns to proper names and the format showed up nice like this:
Then I tried to add a check box to the right hand side and now the column name boxes are different widths.
Any input on what I need to change to get it to look like the first image(all the boxes the same size) just with the check boxes on the end of each row?
dt=current datatable();
can=0;
ok=0;
var1=0;
FC=1;
SN=1;
L1=1;
L2=1;
L3=1;
L3=1;
PN=1;
Dev=1;
LSL=1;
USL=1;
y=dt<<get column names(string);
listitems={};
ll1={};
for(i=1,i<=n items(y),i++,
	if(y[i]=="PCC_FEATURE_CODE",
		FC=0;
		FCVars = y[i];
	y[i]=="SERIALNO",
		sn=0;
		SNVars = y[i] ;
	y[i]=="LOCATION_1",
		L1=0;
		L1Vars = y[i];
	y[i]=="LOCATION_2",
		L2=0;
		L2Vars = y[i];
	y[i]=="LOCATION_3",
		L3=0;
		L3Vars = y[i] ;
	y[i]=="POINT_NO",
		PN=0;
		PNVars = y[i];
	y[i]=="DEVIATION",
		Dev=0;
		DVars = y[i];
	y[i]=="LSL",
		USL=0;
		LSLVars = y[i];
	y[i]=="USL",
		LSL=0;
		USLVars = y[i];
if(sum(fc,sn,l1,l2,l3,pn,dev,usl,lsl)>0,
	var1=1;
If( can == 1,
Throw();
	nw = New Window( "Launch Dialog",
				<<Modal,
				V List Box(
							Align( "right" ),
							H List Box(
										Panel Box( "Select Columns",
													clb = ColListBox( dt, all, /*<<Set Data Type( "Numeric" )*/grouped )
										Panel Box( "Cast Selected Columns into Roles",
													h list box(
																v list box(
																			h list box(Button Box( "PCC_FEATURE_CODE", clbFC << Append( clb << Get Selected )),
																					clbFC = Col List Box( MinItems( fc ), MaxItems( 1 );, nlines( 1 ))),
																			h list box(Button Box( "SERIALNO", clbSN << Append( clb << Get Selected )),
																					clbSN = Col List Box( MinItems( sn ), MaxItems( 1 ), nlines( 1 ))),
			/*																h list box(Button Box( "LOCATION_1", clbL1 << Append( clb << Get Selected )),
																					clbL1 = Col List Box( MinItems( l1 ), MaxItems( 1 ), nlines( 1 )),cbl1 = Check Box( "needed", 1 )),cbl1<<set(1,1);,
																			h list box(Button Box( "LOCATION_2", clbL2 << Append( clb << Get Selected )),
																					clbL2 = Col List Box( MinItems( l2 ), MaxItems( 1 ), nlines( 1 )),cbl2 = Check Box( "needed", 1 )),cbl2<<set(1,1);,
																			h list box(Button Box( "LOCATION_3", clbL3 << Append( clb << Get Selected )),
																					clbL3 = Col List Box( MinItems( l3 ), MaxItems( 1 ), nlines( 1 )),cbl3 = Check Box( "needed", 1 )),cbl3<<set(1,1);,
																			h list box(Button Box( "POINT_NO", clbPN << Append( clb << Get Selected )),
																					clbPN = Col List Box( MinItems( pn ), MaxItems( 1 ), nlines( 1 )),cbpn = Check Box( "needed", 1 )),cbpn<<set(1,1);,
																			h list box(Button Box( "DEVIATION", clbD << Append( clb << Get Selected )),
																					clbD = Col List Box( "Numeric", MinItems( dev ), MaxItems( 1 ), nlines( 1 )),cbd = Check Box( "needed", 1 )),cbd<<set(1,1);,
																			h list box(Button Box( "LSL", clbLSL << Append( clb << Get Selected )),
																					clbLSL = Col List Box( "Numeric", MinItems( 0 ), MaxItems( 1 ), nlines( 1 )),cblsl = Check Box( "needed", 1 )),cblsl<<set(1,1);,
																			h list box(Button Box( "USL", clbUSL << Append( clb << Get Selected )),
																					clbUSL = Col List Box( "Numeric", MinItems( 0 ), MaxItems( 1 ), nlines( 1 )),cbusl = Check Box( "needed", 1 )),cbusl<<set(1,1);,
																			Button Box( "Remove",clbPC << Remove Selected,clbSN << Remove Selected,clbL1 << Remove Selected;clbL2 << Remove Selected,clbL3 << Remove Selected,clbPN << Remove Selected,clbLSL << Remove Selected,clbUSL << Remove Selected,clbD << Remove Selected;
															v list box(
																		cbfc = Check Box( "needed", 1 ),cbfc<<set(1,1);,
																		cbsn = Check Box( "needed", 1 ),cbsn<<set(1,1);
							H List Box(
										Button Box( "OK",
													/* Retrieve the selected items as column references */
													if(fc==1,FCVars = clbFC << Get Items( "Column Reference" ););
													if(sn==1,SNVars = clbSN << Get Items( "Column Reference" ););
													if(l1==1,L1Vars = clbL1 << Get Items( "Column Reference" ););
													if(l2==1,L2Vars = clbL2 << Get Items( "Column Reference" ););
													if(l3==1,L3Vars = clbL3 << Get Items( "Column Reference" ););
													if(pn==1,PNVars = clbPN << Get Items( "Column Reference" ););
													if(dev==1,DVars = clbD << Get Items( "Column Reference" ););
													if(lsl==1,LSLVars = clbLSL << Get Items( "Column Reference" ););
													if(usl==1,USLVars = clbUSL << Get Items( "Column Reference" ););
										Button Box( "Cancel" )
If( nw["button"] == -1,
Throw();
Thanks for any ideas.
Steve
Re: Sizing input boxes
I would most likely try doing this with Line Up Box. Something like:
FC=1;
SN=1;
	<<Modal,
	V List Box(
		Align( "right" ),
		H List Box(
				Lineup box(N Col(3),
					clbFC = Col List Box(MinItems( fc ), MaxItems( 1 ), nlines( 1 )),
					cbfc = Check Box( "needed", 1, <<set(1,1)),
					clbSN = Col List Box( MinItems( sn ), MaxItems( 1 ), nlines( 1 )),
					cbsn = Check Box( "needed", 1,<<set(1,1))
FC=1;
SN=1;
	<<Modal,
	V List Box(
		Align( "right" ),
		H List Box(
