qdread
Simulate non-pro jmp with a jmp pro installation
Apologies if this is a duplicated question as I am new here. I searched for an answer but cannot find it.
I am a statistical consultant who typically does not use JMP for my own work; I use R and occasionally SAS. I have a JMP Pro installation from my employer to use if clients ask me to help them with JMP. However, many of these clients do not have JMP Pro themselves. So sometimes it can be difficult for me to help them because I do not know off the top of my head which JMP features they can and cannot reproduce on their own systems. Is there an easy way, besides searching through all the documentation, to "simulate" non-pro JMP with an installation of JMP Pro? Can I somehow temporarily disable the Pro-only functionality so I can see the same thing that the client would see on their system? Thanks very much in advance.
vince_faller
Re: Simulate non-pro jmp with a jmp pro installation
You can disable it from JSL
Names default to here(1);
preferences(disableJMPPro(1));
Vince Faller - Predictum
I am not familiar with such an option, but I sure like the idea of having a switch, or at least, having a way to have a separate copy that is just JMP and not JMP Pro.
I urge you to add this idea to the JMP Wish List so it will become a recorded suggestion.
Although not exactly what you are looking for, this might help.
If you go to View > JMP Starter, you will see categories of things that JMP can do. As you click on each category, you will see each item in that category on the right. The items that are in JMP Pro have the JMP Pro logo.
Dan Obermiller
qdread
That's extremely helpful, thanks! I guess I'm surprised that the Mixed Model option is only available in JMP Pro. These days it's kind of the default for me . . .
vince_faller
Vince,
This is a GREAT piece of information.
althompsonphd
Great solution and a big help. The next question that I have is how to enable JMP Pro again. I have tried what I think to be the obvious solutions, but I am having no luck. Thanks for any assistance!
