I want to clarify the following:
1st. I said I will use DSD if the factors are continuous and 2-level categorical. However, this tool is not appropriate if there are any linear inequality constraints on the factors or disallowed combinations of factor levels. I did not say it is appropriate for every situation.
DSD will answer your point number 1 (constraints). Time, Money, and material availability because it is more efficient than other designs. Use DSD if it fits the situation.
2nd. If any criteria does not match the DSD. Then I think the all-purpose Custom design works best.
In screening phase, do you recommend adding two-factor interaction or main effects is already enough?
or Main effects only and make alias optimal? What is the best way to do it given I have all the time, money and etc?
Given  the time, money and etc. Do you always recommend Repeats, RCBD, BIB?
Split-plots are use for hard to change factors.
Actually, I do not fully understand covariate factors, when to use it.
How do I know that I eliminate noise?
3rd After screening phase. Since I know already the factors that are significant. I can use Augment Design to add higher order effects like 2-factor interaction and/or quadratic for process factors and 3-order effects (3-factor interaction and cubic) for mixture/formulation.
If I know already the significant factors. I can skip the screening phase and will go straight-ahead adding 2-factor interaction, quadratic effects for process factors and 3rd-order effects for mixture/formulation.
Please enlighten me about leverage/stability, measurement uncertainty, and mean/variation?
Thank you very much
