  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Matt_C
Short Date () creating a locked character column
When I create a "date" column in the script below it creates a locked (so I can not change the format) column.  Short Date() in the formula looks to be the issue.
The time column stays as numeric after the formula is applied.
How do I get the "Date" to stay numeric?
The date is later in a calender() to set the calender to show only days there is data present.
_____________________________________________________
//Open
dt_run = Open( "data.jmp");
dt_run << New Column( "Date", Numeric, Continuous, Format("m/d/y"), Input Format( "m/d/y h:m:s"));
Column( "Date") << Add Column Properties( Formula( Short Date( :Name( "Date & Time" ) ) ) );
dt_run << New Column( "Time", Numeric, Continuous, Format("h:m"), Input Format( "m/d/y h:m:s"));
Column( "Time") << Add Column Properties( Formula( Time Of Day( :Name( "Date & Time" ) ) ) );
Thanks
Matt
Re: Short Date () creating a locked character column
The issues you are having are with the understanding of what the Short Date() function returns.  It does not return a JMP date value, which would be the number of seconds since 12:00am, January 1, 1904, but rather, it returns a literal string of the date part of a JMP date value.  To illustrate this, the following JSL displays what Short Date() returns:
show(short date(today()));
 and it returns
Short Date(Today()) = "12/03/2019";
And since in your JSL it returned a literal string, it changed the Date column to a character column.
Really, what you want is to use the DateMDY() function to create the date value.
Below is a reworked version of your code that does what I believe you need:
Names default to here(1);
dt_run = new table("data",add rows(1), new column("Date & Time",formula(today()),format("m/d/y h:m:s")));
dt_run << New Column( "Date", Numeric, Continuous, Format("m/d/y"));
Column( "Date") << set Formula( DateMDY(Month(:Name( "Date & Time" )),Day(:Name( "Date & Time" )),Year(:Name( "Date & Time" )) ) );
dt_run << New Column( "Time", Numeric, Continuous, Format("h:m"));
Column( "Time") << set Formula( Time Of Day( :Name( "Date & Time" ) ) );
 and it returns
Matt_C
Jim,
Thanks for such a well explained answer. Your posts are always informative, educational and easy to follow.
Matt
Given a little more thought on your JSL.......you could use the following to get your Date column populated
Column( "Date") << set Formula( informat(Short Date( :Name( "Date & Time" ) ), "mm/dd/yyyy") );
It just uses the Informat() function, which takes a literal string and returns a numeric JMP Date value
vince_faller
You can also do it using only the number by changing date time from seconds to days and flooring.
Names Default to Here( 1 );
dt = New Table( "Test",
	Add Rows( 1 ),
	New Column( "DateTime",
		Numeric,
		"Continuous",
		Format( "m/d/y h:m:s", 23, 0 ),
		Formula( Today() ),
dt << New Column("Date",
	Numeric,
	"Continuous",
	Format( "m/d/y", 23 ),
	Formula(
		num_s_per_day = 24*60*60; // # seconds/day
		Floor(
			:DateTime // take the date time which is a number in seconds
			/ num_s_per_day // turn it into days by dividing
		) // this will round down to the day
		* num_s_per_day // turn it back into seconds (a date time)
Vince Faller - Predictum
