Hi @ZA : Yeah, it may not be any sort of "standard" calculation; that said, it could be informative as it could be seen as an estimate of how much of a mean shift may have occurred. You may have to calculate it yourself; via some slick JSL (I'll leave that to the experts), or just create another column in your data that identifies the rogue n=9, then calculate the summary stats by that new column? Or, you could use the Y by X platform and choose that new column as X (so long as it is a character/nominal factor).
I'm sure there are other ways...
