Newbie_1
Setting the size of graphs
Is there a way to set a default size for graphs?  I like my Predicted Vs Actual graphs to have a pixel size of 325 x 325.  Instead of going in after the fact, I would like to set these as a default size.  But I can find nowhere in the Platform Defaults to change this setting.  Is this possible, or does JMP not have a way to specify the size of graphical output.
Thx!
SDF1
Re: Setting the size of graphs
Hi @Newbie_1 ,
  I know you can set the default size for the height: File > Preferences > Graphs. In the panel "Graphs", you can set the graph height in pixels. I don't see how to set the width, though.
  However, you can always script it up. If you reference your graph as gb or something, you can send it the command gb << Set Graph Size (x, y), where x and y are the pixel sizes of the graph. See for example the Scripting Index help on Graph Size.
Hope this helps!,
DS
Newbie_1
Thanks.  This didn't really help, but I appreciate the suggestion.
