markschahl
Setting Value Order or Value Label by Another Column
I have an interesting value ordering/labeling problem. See attached files. The data come from a gas chromatograph. The order that matters is not the alpha-sort of the name of the compound but the retention time (R.T.). There are 31 compounds = manual value ordering of the Compound column or manual value labeling of either the R.T. or MW Order columns will be painful and error-prone. Anyone working with chromatographic or spectral data probably has the same issue...
Is there a dialog-driven way to set the value labels or order by referring another column as reference?
Alternatively, does anyone have a script that can do this?
I've also posted an anonymized version of the data table.
Thanks in advance!
mmarchandFSLR
Re: Setting Value Order or Value Label by Another Column
This method assumes you would have to manually add the "MW Order" column, so it just looks at the "R.T" column.  No sorting of the table is needed.
dt << New Column( "Order", numeric, Formula( Col Rank( :R.T. ) ) );
order_list = {};
Wait( 0 );
For Each( {{k, v}, i}, Associative Array( :Order, :Component ), Insert Into( order_list, v ) );
Eval( Eval Expr( :Component << Set Property( "Value Order", {Custom Order( Expr( order_list ) )}, Common Order( 0 ) ) ) );
dt << Delete Columns( "Order" );
7 REPLIES 7
mmarchandFSLR
order_list = {};
Wait( 0 );
markschahl
Thanks! It worked as intended*
* need to add as line #2: dt = Current Data Table ();
hogi
Level XIII
wow, a very elegant way to map the order from one column to another column!
order_list={};
- Associative Array with column references:
  Associative Array( :Order, :Component ) !!! (--> find the documentation)
  automatically: duplicates get skipped, entries ... ordered by keys
For Each( {{k, v}, i} ...  -> {v}
as an alternative:
Associative Array( :Order, :Component ) << get values
mmarchandFSLR
As much as I work with associative arrays, I still forget about the <<Get Values message sometimes!
hogi
Level XIII
application case:
sort states (with name = Abbreviation) by postal code:
Graph makeover: Measles heat map
hogi
Level XIII
alternative solution by @ms
how-to-sort-x-axis-by-another-column-value
Summarize + Rank Index
You can do this also manually
Create summary table (use the statistics as necessary)
Sort your data
Set value order to the column you wish to order in the summary table
Copy Column properties from the summary table and paste to your original table
(I use modified scripted version of this process)
