NRW
NRW
Set Text Box Font to "Light" style
Folks,
Trying to alter the text in a text box so that the style is lighter than normal font. However, the script piece I attached still does not do the trick. I've tried looking at multiple command variations via Scripting Index, but still can't get it to change. I've tried changing the color to give a light appearance.
What am I missing here?
Many thanks
Neil
conf = Expr(
				H List Box(
					spacer box(),
					y =Text box("Footer",
							<< Set Wrap(500),
							<< Set Font("Calibri", 30, "Light"),
					spacer box(),
Neil
Re: Set Text Box Font to "Light" style
Here is a structure that I was able to use to get the font color to work
conf = Expr(
	H List Box(
		Spacer Box(),
		y = Text Box( "Footer", <<Set Wrap( 500 ), <<Set Font( "Calibri", 30 ) ),
		Spacer Box(),
New Window( "test", conf, y << Font Color( "Gray" ) );
gzmorgan0
@NRW ,
I am not familiar with Font Style "Light."  I would change the font color to gray.  See script below,
New Window("test",
	H List Box(
		Spacer Box(),
		y = Text Box( "Footer", <<Set Wrap( 500 ), <<Set Font( "Calibri", 30 ), ),
		Spacer Box(),
Wait( 2 );
y << Font Color( "Gray" );
NRW
NRW
Many thanks for the reply!
In order for it to work within the expression I attached, what needs to be changed? The insertion of the font color, the way I have it does not work.
conf = Expr(
				H List Box(
					spacer box(),
							<< Set Wrap(500),
							<< Set Font("Calibri", 30),
					spacer box(),
y << Font Color("Gray");
Neil
conf = Expr(
	H List Box(
		Spacer Box(),
		Spacer Box(),
NRW
NRW
Gentlemen,
Many thanks for your generous time. Your suggestions worked. This was helpful since I have several Expressions which are image and title sub blocks that integrate into a final image that gets copied to PowerPoint (script attached with your solution).
As an aside, I tripped across a possible alternate approach (via Scripting Guide - p. 558) using HTML Tags. I tried this  which works as well.
Again I'm very grateful for your valuable time.
Neil
 text = Expr(
			H List Box(
				spacer box(),
				y = Text Box("Footer",
				<< Set Wrap(500),
				<< Set Font("Calibri", 18, "bold"),
				spacer box(),
nw6 = Expr(
			V List Box(
				text,
				spacer box(size(5,50)),
				nw4
nw7 = New Window("title_7", nw6, y<< Font Color("Gray") );
// ** Alternate **  HTML Tags//
 text = Expr(
			H List Box(
				spacer box(),
				y = Text Box("<font color='Gray'>Footer</font>",
				<< Set Wrap(500),
				<<Markup),
				spacer box(),
Neil
