Jemster
Set Spec Limits to Display on Histogram
I have a function to set spec limits below and I would like to adapt this code, or add to it, to let me toggle displaying the lines on the histogram as is an option in the column properties menu as 'Show as Graph Reference Lines'
SetSpecLimits = function({c, lsl, usl, tar},
     cmd = Expr(c << SetProperty("Spec Limits", {LSL(expr(lsl)), USL(expr(usl)), Target(expr(tar))}));
     eval(evalexpr(cmd));
Jemster
Re: Set Spec Limits to Display on Histogram
I altered my code to Show Limits
     cmd = Expr(c << SetProperty("Spec Limits", {LSL(expr(lsl)), USL(expr(usl)), Target(expr(tar)),Show Limits(1)}));
Not exactly sure how you would like it to work, but you could add Show Limits to the function.
Change Spec Limits column properties manually and enable "Show as Graph Reference Lines", then copy the script from Enhanced Log or from Copy Table Script (no data) for table or from column properties. Then modify your function accordingly
View more...
SetSpecLimits = function({c, lsl, usl, tar, s = 1}, {Default Local},
		{LSL(expr(lsl)), USL(expr(usl)), Target(expr(tar)), Show Limits(Expr(s))}
SetSpecLimits(Column(dt, "height"), 60, 70, 65, 1);
SetSpecLimits(Column(dt, "weight"), 60, 70, 65, 0);
Jemster
View more...
