Diana
How to make p-Value shown in scientific notation format?
Hi all,
I'm checking and reviewing statistical results done by others using different statistical software tools. Their p-values are at range <0.00001 displayed in scientific notation. Some numbers are strange. When I using JMP to repeat the analysis, Fit Y to X and then select the relevant method, the p-Values are shown as "<.0001". Is there a way to for JMP to show the p-value in scientific notation format so that I could compare the results number?
Thanks,
Diana
Re: How to make p-Value shown in scientific notation format?
Right click on column header and select Format Column...
