PowerOx327
Is there any way to create a multi-layer array?
1) I'm trying to create a multilayer array where one key, gets multiple layers. Is there any way to do this. For example, my jsl should look like:
EX = Associative Array( {"Blue", "Green", "Red"}, {1, 2, 3}, {"Bear", "Gecko", "Rabbit"} );
I'm trying to get it so that if I select "Blue", I get both 1 and "Bear".
2) Is there any way for an array to map for a function. For example,
EX = Associative Array( {"Blue", "Green"}, {functionA, functionB} );
Is there a way that the value returned triggers a function? I've tried and the values I get are in terms of string i.e if I select "Blue", I get the string "functionA" instead of it executing functionA.
ErraticAttack
Re: Is there any way to create a multi-layer array?
Unfortunately JMP does not offer a zip() function for lists, but you can easily make one as a solution to your first item:
zip = Function( {list a, list b},
	{zipped, i},
	zipped = {};
	Summation( i = 1, Min( Length( list a ), Length( list b ) ),
		zipped[i] = Eval List( {list a[i], list b[i]} );
		0
	zipped
EX = Associative Array( {"Blue", "Green", "Red"}, zip( {1, 2, 3}, {"Bear", "Gecko", "Rabbit"} ) );
Show( ex )
For your second item, see the function Name Expr() -- it should do what you want.  Note however that due to limitations of the JSL parser, you will have to first set a temporary variable for the function to land in, then call from that temporary variable.
	{zipped, i},
	zipped = {};
		0
	zipped
EX = [=>];
EX["zip"] = Name Expr( zip );
func = ex["zip"];
Show( func( {1, 2, 3}, {"Bear", "Gecko", "Rabbit"} ) )
Jordan
Georg
Just another way to implement would be the following:
// nested structure
EX = Associative Array( {"Blue", "Green", "Red"}, {{1, "Bear"}, {2, , "Gecko"}, {3, "Rabbit"}} );
Show( EX["Blue"] );
// Function example
myadd = Function( {op1, op2},
	op1 + op2
mymult = Function( {op1, op2},
	op1 * op2
func_aa = Associative Array( {"add", "mult"}, {myadd, mymult} );
myfunc = func_aa["add"];
Show( myfunc( 1, 2 ) );
Georg
